Originally Posted by Ferocity02
(Post 5192308)
I use the stock PCV system with a check valve and catch can inline. The check valve prevents the boost in the intake from going through the PCV lines into the crankcase.
And then I run a single 3/8" line from the passenger side valve cover to the turbo inlet pipe. I was worried that the single 3/8" line wouldn't be enough to vent the crankcase while in boost, but it seems to be working fine. I've never pushed out the dipstick. I may upsize the line anyways and plumb it from the oil filler cap to the turbo inlet. |
2 Attachment(s)
(Post 5192308)
And then I run a single 3/8" line from the passenger side valve cover to the turbo inlet pipe. I was worried that the single 3/8" line wouldn't be enough to vent the crankcase while in boost, but it seems to be working fine. I've never pushed out the dipstick. I may upsize the line anyways and plumb it from the oil filler cap to the turbo inlet. Here is the check vale i used Check Valves Catch can Attachment 105761 Fresh air side hooked in pre turbo I had another check vale there originally but i removed it after being told it was bad idea. Which it was a bad idea. Attachment 105762 |
hard to see but does the line off the turbo go to the bottom fitting of the catch can? then top fitting goes to motor?
Corey, why no AN fittings on the check valve?? Looks a little out of place.... :P
Originally Posted by timmay208
(Post 5192330)
Originally Posted by AKlowriderZ71
(Post 5192332)
All I did was remove the oil fill cap, add a baffled filter in place, no more oil.
I assume you also plugged the stock vent location?
(Post 5192380)
I'm running an upgrade PVC valve from a ford tbird turbo.
TB is capped and pass valve cover has a breather |
| All times are GMT -5. The time now is 07:32 AM. |
