-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   venting crankcase (https://www.performancetrucks.net/forums/forced-induction-159/venting-crankcase-526601/)
02_Orange_D1SC Feb 13, 2014 10:44 PM
venting crankcase
well i took my truck out for a quick ride the other day and blew the dipstick out and soaked the engine with oil :bang:
so whats the best way to vent the crankcase
timmay208 Feb 13, 2014 10:47 PM
ditch the pvc and do a catch can
Blown06 Feb 13, 2014 11:26 PM
Mine did the same thing when I was on a d1sc. I have a catch can that I welded a couple hose barbs in so that it connects directly with each stock valve cover. It's an aluminum can with a breather on top. I'm not using it so if you want it let me know.
Byrdman11 Feb 14, 2014 06:21 AM
Did you install a one way check valve in the Pcv? Did not you are putting boost in the crank case.
6.0l RST Feb 14, 2014 07:28 AM
soooo much to cleaannnn.
Vortec350ss Feb 14, 2014 08:07 AM
why not just get a oil fill with a filter on it and cap off the original vent location?
GRRR65GTO Feb 14, 2014 08:53 AM
I just posted up some pictures of the catch can in my thread. I ran 3/8 hose from both valve covers to it
03sierraslt Feb 14, 2014 09:09 AM
How is your current pcv system setup?
boostedsl2 Feb 14, 2014 09:24 AM
I would ditch the PCV valve all together. You can weld/plug the port on the tb and run the lines to a catch can. you'll also need to plug the port on the intake.
Filers are on a catch work great. You can always add a line from the catch can before the TB (or turbo inlet) to pull a little vacuum at idle to suck the catch can smell.
here's a few photos of my setup
http://alphatuning.com/TurboTruck/Truck-019.jpg
http://alphatuning.com/TurboTruck/Truck-007.JPG
GMCtrk Feb 14, 2014 09:43 AM
I have a vented catch can attached to my drivers side valve cover (I drilled out the Pcv valve). And I have a line from my air filter to the passenger valve cover to pull vacuum on the crankcase under boost.
