Twins and not what u'r thinking. hint TVS 3800.
Well this build was pretty special. took me almost 5 months to build, and wait on parts. Hope yall enjoy as much as I did building this.
Some will ask why? the answer is Becuase.:devil: We used dual 1900 superchargers 8rib 3" pulleys,:eek: ATI 8 rib drive pulley at the crank. Magnacharger got me 2 of these with the bypass controll valves on opposite sides. So free'd up the middle for the air box. Intake is a billet piece with meth injection bar. 3/8npt for an air temp sensor, and dual 1/8 for boost ports. intercooler 3.5" 3 / 3 in and out -10 fittings. Custom fuel rails and rail brackets Upper plenium is made up of 3/8,1/2, and 1/8 aluminum. It was bolted together then welded out. Air inlet and rear plenium are modular so they can be expanded if room allows. Front drive mounting plate is 1/2 aluminum. Tentioner is an off the shelf part I modified to expect ATI's idler pulley. http://www.trickperformanceproducts....0_3191_jpg.jpg Rear blower inlet area http://www.trickperformanceproducts....0_3194_jpg.jpg http://www.trickperformanceproducts....0_1007_jpg.jpg Billet intake http://www.trickperformanceproducts....0_1000_jpg.jpg http://www.trickperformanceproducts....0_1005_jpg.jpg Lots more intake material. :D also billets for main blower idler. http://www.trickperformanceproducts....0_1001_jpg.jpg 18+lbs ligher. lol http://www.trickperformanceproducts....0_1003_jpg.jpg 8rib - 1/2 main plate - dual belt system Blower belt is wrapped onto other side of idler pulley to help any loading on the water pump shaft. http://www.trickperformanceproducts....0_3185_jpg.jpg Spring loaded tentioner Main idler, you can see there also a provision for another idler on the main bracket. We did not need it in the end, but its there. http://www.trickperformanceproducts....0_3197_jpg.jpg Altenator relocation bracket. had to swing the altenator over to clear the top air box and blower. http://www.trickperformanceproducts....0_3184_jpg.jpg |
Nifty. Does it run?
Looks great. Lot's of $ in there!
That is sick!!!!
HOLY SHEIT!!!! Trickest of the trick!
Damn I want one.
all i can say is wow. how much boost is this going to run? could this be a future kit for sale? what keeps the blower pulley thats over the water pump pulley in place?
:eek: wow thats sweet
you forgot to mention that its a 427 LSX block:D
I think Rick said its going to be pushing 20 lbs. of boost |
nice work!!!!!!!!
are u expecting issues with heat? -Nate |
