Twin turbo manifolds are in stock.
I would want everything else. I would keep the passenger manifold of course and sell the rest of my stage 2 kit.
I really like these cast manifolds, but I want to use them in a different car. I am pretty sure that the accessory system that I want to use will not be a problem. Is there a sheet that shows the exact dimensions of the manifolds? I have limited width, so knowing how far past the heads the manifolds sit would be super helpful. Also the approximate height of the turbo mounting flange? Something like this would be even more helpful:
I am actually currently using the Hooker manifolds in the above image, and I can't go much wider. This is in a 1967 Cougar with a LS swap.
Thank you!
Andrew
Thank you!
Andrew
TrickTurbo (01-31-2019)
Yeah I've been looking for a different ride. I'm gonna jump ship this year and when I get settled, pretty sure I'll be going with Rick. Some of the new stuff on the market is tempting but Rick just has so much credibility. And you are a strong deciding factor because of your report and recommendation. So, thanks!
Thank you!
Andrew
Thank you!
Andrew
if you buy a set and they don’t fit. You can send them back and only out the freights.
