'Truck' Procharger kit fit onto TBSS?
I have made the decision to return my Tahoe as close to stock as I can, and am looking to invest my money into a TBSS.
I wanted to save a couple parts to be used on the trailblazer, but wanted to check on the fitment.
One was my Procharger kit. For my truck it mounts on the driver side, but the TBSS kits that I have seen are all on the passenger side. I know the truck piping lays out differently, but I wanted to check if there is anything on the drivers side that would block the headunit from fitting and making my own piping for it.
If not, then would the same headunit work on the passenger side with the different bracket?
Also, I have a performabuilt trans and circle d converter that I want to use as well. It has the 4wd output shaft which I wanted to verify is identical for use in an AWD.
I saw a tbss awhile ago that had a procharger on the driverside. I don't remember if it was a truck kit or a car kit. as you have seen most everyone goes with a hob setup. Runs it on the pass side. tbss are a funny deal as some items on the motor are truck items and some are car. Kinda makes them an hybrid for nothing really fitting them without some work.
Yea, I just got a response on tbssowners site with these pics
[/QUOTE]
I guess I'll hold onto the truck bracket for now and try it. Otherwise I'll probably go direct drive from HOB
Edit: also just found this one on youtube:
http://www.youtube.com/watch?v=6SyAp95kuFU
[/QUOTE]
D1SCSS
01-25-2016 10:14 PM
