Trick turbo installation and review
#62
When I did mine and from what I have gathered from the other posts it should be as straight as you can get it. But sometimes it not possible I had to put a 90 in or my hose or it wound kink.
#66
I have a good amount of the install done. waiting on a oil adaptor plate from trick should be here monday then i can get the feed line hooked up. Need to track down oil return line on Monday as well. Other then that I need to change springs in WG , hook up vac lines, install wide band, dash logic, build exhaust system, install fuel injectors, finish heater hoses, extend ground, clock turbo,extend wires for MAF, and thats all i can think of at the moment. Lots to do glad i did not have to do it all in a weekend would have been long days.
