Trick turbo installation and review
#571
Here is a guide...
What?s The Max Overbore For LS Blocks? - Hot Rod Network
"Always sonic-check the block first before going for the max listed overbore."
#572
Here is a guide...
#573
Machine shop called today and said there is no way you can bore out the aluminum lc9 block to 3.898. There is alot of conflicting info out there about it. he said my only option is to go with an iron block and will need to relocate the knock sensor. Also said the custom pistons I orderd from stock48 dont make any sense since they will require an extra thick head gasket to work. This performance stuff gives me a headache.
Any reason not to swap to an iron block? Anything else I need to know before giving him the go ahead? He has one that he will trade me straight across for after he tears it down to make sure its usable.
#574
I have had the driveline clunk for a while but its starting to get pretty noticeable. I am wondering if there is a good upgraded driveline I can get to solve the problem? I figure the factory one was not intended for boost so should probably be upgraded anyway. Any recommendations on drivelines and yoke?
#575
Sent the machine shop some link's on boring the lc9 to 3.898 and he replied that he will bore my block. He did some research and contacted some ls experts and he is going to do it. I am glad I shipped my block to these guys. No way any of my local shops would have taken the time to do research.
#576
is this on a nnbs? I'm trying to do the same thing on my nnbs to make more room for my turbo build. Im not sure if I need a overflow or expansion tank, do i need a inline fill cap, & how do i route it all? This is my current oem setup. Goes from top right of radiator to top of oem expansion tank & bottom of expansion tank T's into the heater hoses by the water pump.
#577
Truck Sponsor
Some guys turn that tank or install a vette tank or do a puke tank.
It really not needed to do change with our kits. But some do to gain more clearance and access gate easier.
The puke tank type will not pull water back into the system if it does puke some out.
So you will need to check to see what's going on.
Expansion tanks allow you to see levels plus adds a little more volume. And in the event you do over heat and loose some fluid out. You will be able to see what's in the tank. Low level light etc.
#578
This is a nnbs. You can use an expansion or recirculating tank. You need to put the fill cap in the top radiator hose like the pic shows. Plug the small line going to the stock tank at the radiator. Cant remember how i got rid of the large line but it needs to be plugged. Then run a line from your filler cap to your new expantion tank. The tank you choose will have directions on how to set it up.
Also I think atomic makes a custom tank for nnbs now.
#579
Time to change things up a little. Had Rick at trick performance make me some stuff. Really excited to see how the ic and piping is going to look when installed. My goal is to keep everything under the hood clean and hopefully when you open the hood the turbos will stand out like a sore thumb.
I've been very happy with the quality of the single kit from trick performance so I'm going continue on with them and see how this twin setup comes together.
