-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Target Lambda/AFR with E85 (https://www.performancetrucks.net/forums/forced-induction-159/target-lambda-afr-e85-496881/)
Beatdown Z Feb 11, 2012 05:08 PM
What Lambda/AFR are you E85 guys commanding in boost?
marovetsm Feb 13, 2012 05:26 PM
My stoich is 9.706 and PE eq ratio of 1.25 all across the board.
scooter k Feb 13, 2012 05:41 PM
.78 is what my wideband shows on Lambda
Lextech Feb 14, 2012 11:37 AM
After the stoich value of the fuel is entered into the tune as AFR, the PCM bases all of its fueling calculations on EQ ratio. It is best to think and tune in EQ. My E-85 boosted EQ ratio is 1.22
Jeff
Atomic Feb 14, 2012 12:21 PM
lambda = 1/equivalence ratio
(for those that didnt know)
Beatdown Z Feb 14, 2012 03:46 PM
I've read multiple times that E85 likes a richer mixture, so I have my EQ ratio set at 1.31 or .76 lambda. Haven't had much time to play with it, but it feels pretty good.
Has anyone spent time on a dyno adjusting their EQ ratio up/down?
ChevyTruck Feb 14, 2012 04:04 PM
Off Topic Question. Where are you getting your E85 at Justin?
sharpshooter Feb 14, 2012 04:36 PM
Only station in DE I know of is on 40 near Bear.
ChevyTruck Feb 14, 2012 05:25 PM
I just wasn't sure if there is another station, he's close to the PA border.
Justin, I'd like to see that thing in action.
Beatdown Z Feb 14, 2012 08:37 PM
That's the one. Only about 13 miles from my house...
It's running right now, but still needs the intercooler hooked up. Hopefully next week I can drop it off at my friends shop so he can weld it up. Hoping to make some shakedown passes March 3 at Cecil.
