Switching Pulleys. To much Boost?
Old Jan 26, 2009 | 08:50 AM
jkru617's Avatar
Default Switching Pulleys. To much Boost?
I have a vortech v2 on a 4.8 rcsb with LT. Tuesday Im putting on a 2.62 pulley with anywhere from 11-15 psi from a 3.33 with 7 PSI and 42# injectors.
Is this to much for my engine?
Old Jan 26, 2009 | 08:51 AM
nighthawk08's Avatar
you have the aftercooler right? as long as you tune it well it should be fine.
Old Jan 26, 2009 | 09:04 AM
jkru617's Avatar
no aftercooler but Im getting it tuned
Old Jan 26, 2009 | 09:13 AM
03sierraslt's Avatar
Do you have Meth?
Old Jan 26, 2009 | 09:20 AM
jkru617's Avatar
No meth either
Old Jan 26, 2009 | 09:26 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
too much
Old Jan 26, 2009 | 09:36 AM
jkru617's Avatar
dang. whats a good number if I want to upgrade Pulleys? 10 PSI? vortech pulleys say 1-2 PSI per pulley size down. I went down 4.
Old Jan 26, 2009 | 11:50 AM
trever1t's Avatar
I think most will agree 10lbs on a stock block with good tuning and methanol is doable. I know others make more (i make ~11lbs) but for the most part 10 is where the line is drawn in the sand.
Old Jan 26, 2009 | 12:14 PM
S/C Z71's Avatar
Banned
All good. Just get a tune.
Old Jan 26, 2009 | 12:15 PM
jkru617's Avatar
Thanks. Maybe Ill just keep the stock Pulley and buy some cams instead.
