supercharged crankcase ventilation
Old Sep 7, 2007 | 04:39 PM
moregrip's Avatar
what a rush!
Originally Posted by ranwalk
Why not leave it run the way it has been all along? Did you have some problems with it like that?
essentially it would be the same, just pulling from a different valve cover, drivers vs passenger, what do you think?
Old Sep 7, 2007 | 05:30 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
PCV does pull from the DS cover stock Dev. The PS side is the fresh air intake.
Personally, unless you're having trouble with oil through the PCV or positive crankcase pressure, I'd leave it alone.
Having said that, I did add KrankVents and catch can to my build sheet lol. I routed the PS side to my intake vac port, but have the STS positive pressure switch there anyway. On the DS, I run the PCV to the catch can, catch can to the KrankVent, KV to the manifold (like Bill's setup on that side).
Old Sep 7, 2007 | 05:42 PM
moregrip's Avatar
what a rush!
I don't think I'll need any one way valves, and I swore the radix setup pulled from the passenger, I guess my memory is tired.
Old Sep 7, 2007 | 05:52 PM
I AM A MOTHERF*CKER
Oh it might I guess. The stock setup doesn't
Heh -- guess we should define 'pull' too
My understanding is this: fresh air comes in the passenger side vc. Crank air flows back into the manifold via the driver's side vc.
Old Sep 7, 2007 | 05:54 PM
Stock PCV is on drivers side passenger side is to the intake.I have gone to a LS6 setup that pulls from the valley cover.
Old Sep 7, 2007 | 08:07 PM
XLR8NSS's Avatar
Adkoonerstrator
I think your plan is fine grippy except no real reason to change the connection points. No need for the one way valve since the intake tube on a radix doesn't see boost. Really the only thing you'll be changing from stock is the catch can which is not a bad idea.
When I took my radix off I didn't see much oil in the intake runners, relatively normal amount for any of the Gen III engines.
Old Sep 7, 2007 | 09:34 PM
Holty's Avatar
Notorious BIG
fwiw, wkdivr and I both have our catch cans setup just like you described grip.
moregrip
Jul 26, 2016 11:21 AM
5speedsilverado
Sep 25, 2015 06:50 PM
bagged7104SS
Sep 24, 2015 08:42 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
