"Suped" up the Avalanche
I installed a Roush tvs 1900 on my 2012 Avalanche this weekend. I spent about two months putting together parts and I finally put it in. The only snag which a PT member informed me of ahead of time is the 2010 up trucks and suvs have a 1 piece fuel rail and the kit is made for a 3 piece fuel rail. This would have been bad to figure out the day of the install so thanks Dyno Dan for the heads up. Dyno Dan also found a map connector pig tail that I used to allow for only one factory wire to be cut for the install. I wanted more than 7 to 8 lbs of boost so I went ahead and put on a powerbond 10% overdrive crank pulley. The pulley is a 8 rib but works like a champ on my 6 rib accys. My tuner would not dyno the truck because he has had several trucks throw a drive shaft so he street tuned it for me. He said based on the air it was moving he estimated 450 to 470rwhp. He has done thousands of tunes so the estimate should be pretty close. I do not have a boost gauge yet but he said it was 9lbs plus.
The heavy behemoth runs pretty good it hits second hard and actually chirps third with my 33" terra grapplers. I tried a 4wd launch and it spins the front tires I guess I will have to take it to the track one day just for fun.
Here is the picture of how the belt sits on the powerbond balancer pulley.
Apperance wise I have a 2.5" leveling kit on the front with a 1.5" spacer on the rear with 305/55/20 terra grapplers. My next project is to put some helper bags in the back.
