Stock48 S475/83 Nova first time out!!!!
I know it's not a truck but still kinda cool. Figured Id let you guys in on what I have been working on, and why I have been neglecting truck..
Just got my car running last week and figured since they were running tnt sat I would shake it down a little. Car is a 1972 Nova I have been putting together over the last year in my not so spare time. Has a Stock bottom end lq4 that I pieced together from mostly used parts I purchased off forum members over on Pt. Has mild cleaned up stock valve 317 heads and my stg 2 truck cam. Engine is actually for my sand truck. I drive car all over the place and drove it to the track and back 1.5 hrs ea way in 100 deg heat on way there on tires I raced on. Runs were thru full exh just like I drove it there. Car is not finished yet and has a ton left in it. All runs were off footbrake in hot nasty *** air, walking it out of the hole. No 2 step used. Was just shaking car down. This is the 10.30/128mph tune up from my truck. Rundown
-1972 Nova all steel except for bumpers
Stock suspension with caltrac bars, (Guessed where they needed to be and haven't messed with them yet)
-6.0L lq4, 317 heads, JFR Isky 218/112 cam.
-S475/83, T4 @16 psi boost with KBRacing truck turbo kit. 4'' dp full 4'' exh, and muffler. Treadstone a2a I/c.
-Stock truck intake, and TB, Deka 83 lb injectors@75 psi base, E70.
-Holley HP efi, with 2 bar map.
- Stock 8.5'' 10 bolt, strange axles, 3.23 gear.
-Stock case glide basic 750 hp build, YANK SC 3000, TCI brake( not used)
-Tires are Gen 1 micky 275's that are shot from street( new pro's on order)
-Raceweight was 3350 lbs with me in car, and 15 gallons of fuel.
Sorry about vid my buddy started filming a little late. This was 5.73/127 mph in 1/8, 1.49 60'. I let off right after 1/8 and on brakes at 1000'. This was 3rd run on car. I have 8.5 cage but no chute or lic.
Ended up going 8.9/157.5 in 1/4 having to let clear out at 150' into run pulling high gear and getting back in. Also had to peddle it around 1000' mark. They ran me right after the jet cars and there was jef fuel all over track. It had a high 60 0r 70 in it but I got screwed. I'll take the 8.9 over a crash tho.
Famoso 5 2013 06 16 22 29 00 - YouTube
