started running lean
Old Feb 19, 2012 | 06:12 PM
14psisupra's Avatar
I would think a burned wire would cause a misfire but ill go over them tomorrow. And my wideband is supposed to self calibrate everytime on startup
Old Feb 20, 2012 | 08:31 AM
14psisupra's Avatar
Couldn't drive it but idling and a few small revs fuel pressure stays just above 60.
Offtopic - if I'm going to the tuner later this week and dropping tire size about an inch. Should I mount them up or is it not enough to effect anything
Old Feb 24, 2012 | 10:07 AM
14psisupra's Avatar
well, said i had a few lean tables, went ahead and put about 8-9psi on, retuned and got some new numbers, made 463hp/478tq,made 480hp on a 10psi run,seems reached my goal of 450
Old Feb 24, 2012 | 10:48 AM
oakley6575's Avatar
Why did you drop the boost? You couln't tune out the lean spots with 10psi?
Old Feb 24, 2012 | 10:53 AM
14psisupra's Avatar
just trying to keep it safe as possible(daily driver), not sure when head bolts are really needed and at least until i can get an 80e swap im sure it will see 10psi daily, my 60e is built but still pushing a crew cab with a 30inch tire
Old Feb 24, 2012 | 11:07 AM
oakley6575's Avatar
Who does your tuning?
Old Feb 24, 2012 | 11:17 AM
14psisupra's Avatar
flaco
stealthperf
34
Feb 14, 2016 11:35 AM
steves86ta
Jul 28, 2015 10:21 AM
atxlt
Jul 20, 2015 11:06 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
signguy62
Jul 16, 2015 05:43 PM
