Should I be running different plugs with a 6.2L @ 8psi
Old Jan 25, 2013 | 08:41 PM
  #21
03sierraslt's Avatar
Stock replacement would actually be a TR5IX I think. 5 is the right heat range for stock and the TR. IX is the iridium I believe.
Old Jan 25, 2013 | 09:02 PM
  #22
tiffo60's Avatar
I haven't added the boost to the denali yet so I can't say, but when I had the lightning I went thru a number of brands, and most recommended the NGK TR6's, but I tried out the denso's and they were the smoothest running plugs I ever put in it, these that I am going to link are the TR6 heat range
Denso 5326 Denso Iridium Power Spark Plugs
Old Jan 25, 2013 | 09:06 PM
  #23
Just so you know Iridium tip plugs tend to hold heat more then a copper core and can be more prone to detonation.
Old Jan 25, 2013 | 09:22 PM
  #24
tiffo60's Avatar
I don't know one way or the other, but I do know high boosted vehicles choose iridium, alot of the 1000hp plus supras I know swear by them
Old Jan 25, 2013 | 09:24 PM
  #25
tiffo60's Avatar
https://ls1tech.com/forums/forced-in...ix-tr7-ix.html
Kateck chose them for there 800hp ZR1
http://forums.corvetteforum.com/c6-c...-delivery.html
Old Jan 25, 2013 | 09:31 PM
  #26
Ok, whatever you choose is up to you.
Old Jan 25, 2013 | 09:45 PM
  #27
dick_landy's Avatar
I run an LS9 plug. Clearly it's working for GM.
Old Jan 25, 2013 | 09:50 PM
  #28
Considering the lack of timing it makes they shouldn't have a issue.
Old Jan 25, 2013 | 10:03 PM
  #29
zachm89's Avatar
im also running a factory delco ls9 plug, ac 41-104 i think is the part number. from what i researched I believe they are either a 6 or 7 heat range plug and they are iridiums. i think it was Janetty that was using them in all of his high hp boosted applications from camaros to vettes and whatever else and swore by them over NGK plugs and since i work for an auto parts store i figured id try them out since i could get them much cheaper than retail. cant say that ive had any problems from them, truck runs good, no detonation so far. ive got a set of br7ef's in my console gapped at about .030 that ive been debating putting in the truck but i just keep putting it off.
Old Jan 25, 2013 | 10:33 PM
  #30
MikeGyver's Avatar
Originally Posted by MB2008LTZ
I find it difficult to think that shorter ground strap in a combustion chamber that has a high compression explosion going off like every half of a second going down the road at 2000 +/- rpms is going to run cooler enough to make difference...but what do I know?
It's not the ground strap's temperature that changes, it is the tip of the center insulator. Here is a good read:
NGK Spark Plugs Canada » Tech Info » Spark Plugs
