problem with boost
hi
i have silverado 5.3 /2010 stock bottom -6.0 heads -ARP studs -MLS gasket -camshaft 226/226 -holley Hi-ram -throttle ls3 -injectors 8000cc -turbo GTX42 housing tail -dual bosch pump 044 -WG precision 66 it was with pip from throttle to intercooler 3 inch i change it to 3.5 the pipe from turbo to intercooler 3inch , down pipe 3.5 when i was tuning its with to side 3 inch its made 550hp with 7psi now i did some upgrade 3.5 pipe and WG precision it was before run with JGS precision 60mm yesterday i tuned the truck the boost never go more than 3 psi /307HP i checked all cooling pipe there is no leaks and i canceled the boost control and checked when i need go more the air fuel ratio is lean i don't know what check now ? using single spring with WG ? or maybe the maf sensor don't work good ? really i don't know .... |
How are you referencing the amount of boost? Are you just running spring pressure in the wastegate, or using a boost controller?
I'm using spring pressure in the wastegate "two springs green and yellow with boost control
at tuning moment i saw the boost never go more so i canceled the boost control and i didn't changed the springs |
| All times are GMT -5. The time now is 07:10 AM. |
