gap 30...
Originally Posted by terravast4
(Post 4724169)
I am only running 11psi and running tr6 gapped at 32 and blowing out the spark at WOT. any recommendations?
I'd also recommend switching to a non-projected tip. I don't recall the part number off hand, but I'm running 7's non-projected, at around .025 gap. |
Originally Posted by AKlowriderZ71
(Post 4724219)
If you are in-fact blowing out the spark, you'll need to tighten up the gap. You want to run as much gap as you can(for driveability), so go a little bit at a time.
(Post 4724169)
This was during a street tune on the freeway. AFR was about 11.4 at wot but varies here and there.
also a speed density tune...if it matters.
(Post 4724330)
If you have time can you tell me what you are running. When I was tuning with Nelson he told me i was blowing out the spark but only at wide open throttle. I thought the gaps had changed. I took them down to around 30 but still doing it.
Thanks AK. I just ask for BR7EF....or does it relate to the year and motor size?
| All times are GMT -5. The time now is 02:38 AM. |
