Plugs for higher boost
Old Jun 25, 2011 | 10:21 PM
  #41
Atomic's Avatar
I have a gauge for that
gap 30...
Old Jun 25, 2011 | 10:27 PM
  #42
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by terravast4
I am only running 11psi and running tr6 gapped at 32 and blowing out the spark at WOT. any recommendations?
If you are in-fact blowing out the spark, you'll need to tighten up the gap. You want to run as much gap as you can(for driveability), so go a little bit at a time.
I'd also recommend switching to a non-projected tip. I don't recall the part number off hand, but I'm running 7's non-projected, at around .025 gap.
Old Jun 26, 2011 | 08:53 AM
  #43
terravast4's Avatar
If you have time can you tell me what you are running. When I was tuning with Nelson he told me i was blowing out the spark but only at wide open throttle. I thought the gaps had changed. I took them down to around 30 but still doing it.
Old Jun 26, 2011 | 09:52 AM
  #44
DrX's Avatar
DrX
I have the BR7EF non-projected that I just put in gapped at .025, which is pretty well what they were at out of the box. I would think you would be OK at .030 as suggested. I never had any issues with the MP112 on the 5.3 at up to 12 psi with TR6 plugs gapped at .032 or .035. Are you seeing this when driving or did Nelson pick it up on the dyno? What's your AFR at WOT?
Old Jun 26, 2011 | 07:28 PM
  #45
terravast4's Avatar
This was during a street tune on the freeway. AFR was about 11.4 at wot but varies here and there.
Old Jun 26, 2011 | 07:29 PM
  #46
terravast4's Avatar
also a speed density tune...if it matters.
Old Jun 26, 2011 | 07:42 PM
  #47
BR7EF non-projected at .025 gap, WOT AFR at 11.7-11.8, open loop speed density.
Old Jun 26, 2011 | 08:25 PM
  #48
terravast4's Avatar
Thanks AK. I just ask for BR7EF....or does it relate to the year and motor size?
fastjweb
Aug 31, 2015 09:57 AM
713truck
Aug 18, 2015 09:32 PM
05GMC4.8
Aug 7, 2015 09:55 PM
76k10chase
Jul 17, 2015 01:48 PM
