Plugs for higher boost
Old Mar 4, 2011 | 06:20 PM
  #31
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by Atomic
....So what range would one shoot for with a 410 and 15lbs of boost with 93 gas and no meth?...
I'd like to know this as well. Would running 91 instead of 93 affect your answers?
I'm about to buy plugs for my 408/12-15psi/10.4:1CR engine. I was planning on TR-6's again as that is what I run on both my boosted engines. This will be the first over 10psi though...
Old Mar 4, 2011 | 07:35 PM
  #32
SILVERADO11's Avatar
I have ran TR6's for 4 years, around 30k miles with no problems. they are my second set, only because i over due maintenance on my rig.
Old Mar 5, 2011 | 01:12 PM
  #33
2004SSS's Avatar
i had mine on 15 psi with tr6's and no problems either . but timing was low , way low like 8* at the end of the pass.
i have the br7ef going in this week . may go to an 8 but i think i will be fine these at 15 psi for the next while . going to 20+ ill go with the 8's.
Old Jun 22, 2011 | 07:53 PM
  #34
DrX's Avatar
DrX
Well I tried the 9's out and I think they are too cold too run on the street. Started out smooth but the more I drove, the rougher the truck was running and I was feeling misses just cruising. Pulled them out after about an hour of use- mostly highway cruising- they were pretty fouled. Put together a fresh set of wires with rubber boots because I noticed that some of the silicone plug boots were not too healthy, swapped in a fresh set of 9's, and it ran better again- for about another hour of use.
Old Jun 24, 2011 | 09:38 AM
  #35
DrX's Avatar
DrX
Thought I would add this link to another thread on 'Tech that has a good plug reference list: https://ls1tech.com/forums/nitrous-o...reference.html
Old Jun 24, 2011 | 07:14 PM
  #36
MikeGyver's Avatar
If you are sure that 9 is the heat range you need for boost, try a projected tip in a 9. The center insulator sticks out like the TR6 in the pic above. It is still a 9 heat range, but because the tip sticks out, combustion is supposed to help burn carbon off the center insulator. I don't know the numbers for our plugs, but for the most common motorcycle plug, you just add a p, for projected tip, into the number. A B7ES becomes a BP7ES.
Old Jun 25, 2011 | 08:54 AM
  #37
DrX's Avatar
DrX
I have had a few recommendations to avoid projected tips in my application. I'm sure cooler plugs will be cleaner after a run down the track.
Old Jun 25, 2011 | 11:58 AM
  #38
MikeGyver's Avatar
Sorry. I think that I can speed-read, but obviously the speed comes from only looking at half of the words.
What is the reasoning behind the anti-projected tip recommendations?
Old Jun 25, 2011 | 06:48 PM
  #39
DrX's Avatar
DrX
That the long ground strap is more likely to heat up and become a source of pre-ignition and/or just burn up.
Old Jun 25, 2011 | 08:18 PM
  #40
terravast4's Avatar
I am only running 11psi and running tr6 gapped at 32 and blowing out the spark at WOT. any recommendations?
