Opened up my TVS2300
#32
Most of the issues are with stock throttlebodies, numerous people claim going to the NW102 solves the issue. Also there are many running stock GM TB's with no issues. Allot of it is in the tune, I have a LS3 TB on mine. The tune does need altered with the larger throttle body. The symptoms his is displaying are different then others, others are having the issue at WO. ETC area scaler needs adjusted, some airflow tables etc.
#33
#35
#37
The wiring is sound on that truck. I personally watched him strip it back and check it. There were a few broken wires at the TB connector and he repaired them correctly Per the GM TSB. We spent 2 hours at the dealer going through every box looking for the correct Pins for the TB connector.
He swapped TB's, tac modules, and pedals with no luck. He replaced the DR.X harness as well and kept having issues.
As soon as he went back to the 87mm the issue stopped.
The issues may be able to be corrected in the tune. I never got a chance to scan the tune and see if we could try adjusting anything. I am not a tuner by any means. No one else could point us in the right direction either regarding aftermarket Throttle Bodies and making adjustments in the tune. He even tried contacting the Tuner and he was not very helpful.
#38
#40
Went ahead and ordered HPTuners last night. Figured im gonna need to learn this stuff at sometime so why not? Woulda been great to have a simple bolt on truck to try and learn this stuff on but I think I can handle it. At least I can do some data logging and send it to my tuner. I have no doubt that with all the help offered on this site this tb issue can be figured out. Good thing this truck isnt my dd!
