Mp112 to mp122 swap using mp112 manifold?
I have the dimensions of both of the blowers if needed. The bolt pattern is not far off but the MP112 manifold cannot be drilled for it as the bolt holes are too close and would break through. I actually was in the process of purchasing an MP112 from Brian @ superchargersonline a few weeks back but pulled back on the decision because of the mounting issues. However, a TVS1900 will bolt right on...
If you can machine, then a 1/2" spacer would be sufficient.
Brian was selling the MP122 for $850 brand new. I believe the pulley alignment would also need to be worked on as well.
You could fill the holes but because it is aluminum, heli-arcing would need to be done.
Here is a comparison of the MP112 and MP122's dimensions. This is from an 2010 Magnuson catalog I found online.
As you can see, assuming the snouts being used are the same, the MP122 will stick out about .200" further than if it were being used on the MP112. Also you can see the mounting pattern is just slightly different.
