LY6 Boost Cam Specs
LY6 Boost Cam Specs
i need some help
i have a LY6 with L92 heads and im having trouble picking out the right cam for it. Boost will be made with a D1 Procharger and a pts3600 stall converter will be used. vvt will be deleted. i plan pushing around 12psi on a 3.6 pulley
What are ur thought or suggestions on what cam i should run???
Im also wanting to change valve springs, pushrods and im adding LS9 head gaskets with a set of ARP head bolts. What else is reccommended?
I was told i should change my rocker arms? Engine has 65K miles.
cam specs
i would call comp cam. this is just my thoughts check be hind me . every one i know who has p/c choose horsepower cam shafts (LOW COMPRESS ENGINES) FOR SOME REASON prochargers like loose converter and deep gears. unlike tubos or whipples style chargers.
