meth nozzle sizes
how do you know what size nozzle to run with your hp/boost? assuming your injectors are the correct size for your setup and your not useing meth largely for fuel.
Originally Posted by 4.8T
(Post 4013961)
350-475 RWHP 375mil nozzle 475-600 RWHP 625mil nozzle This is with a 50/50 mix. From what I understand the more meth in the mix the more your octane will go up but you lose a little of the cooling effect. If you have big enough injectors to handle the fueling you will only need enough meth to add some safety. |
well i have a m15 installed now. not sure of the mil amount though
M15 will go far. I run both an M10 and M15
Rick |
(Post 4014125)
Originally Posted by Rick@Synergy
(Post 4014161)
Rick http://img.photobucket.com/albums/v5...g/P2151053.jpg That M15 will support quite a bit... Are you running strait meth? What fuel injectors? And how high are your shift points? |
question...for meth, shouldn't the nozzles be a little further away to allow it to atomize?
Originally Posted by speedaddict
(Post 4015124)
na there are several turns before it even hits the intake ports |
From the chart I got from STS a m15 nozzle with the small pump has a flow rate of .25 gpm or with the large pump a flow rate of .375 gpm. A US gallon is 3784 ml therefore:
small pump = 3784 x .25 = 946 mlpm large pump = 3784 x .375 = 1419 mlpm |
Originally Posted by Mort
(Post 4015497)
