Meth nozzle location idea for my setup
What do you think about spraying below the blower outlets, pre intercooler core, on my setup? Any reasons this wouldn't work? I have never seen any effect on IAT by spraying pre blower and haven't seen anyone else with a blower that has.
I have a gauge for that
Spraying pre blower my IAT climb rate definitely slowed down, but now my spray bars sit right beside the intercooler in the manifold. Ive never ran it without the nitrous also spraying but saw a 50 degree drop in temps under 15psi of boost with a 150shot at the end of the 1/8th.
Truck Sponsor
Done lots of Ford lightning post intercooler.
If doing spray bars do small holes for each runner.
Say .020 - .036. In the bars. Aiming hole 90' against air flow not with it. Gives better break up. Your fittings need to hold a nitrous jet to allow you to tune / adjust it.
Lots of methanol psi is needed.
Truck Sponsor
The were not aimed at port flow. Think more up.
Feed was not. Back when I did that at the nitrous co. no feed back was good feed back.
Only time we got a call was if a problem had happened.
Injecting nitrous had feed back.
100shot = 90 increase
150shot = 175 increase
200shot = almost 300. Increase
If your air temps are hot with lots of volume (big hp) and you are trying to cool them down.
It's going to take a good amount of methanol spread over a large area to see a true temp drop. Not a false one.
It would be interesting to see the cooling effect of straight methanol as the working fluid inside the intercooler.
Spraying post intercooler is effective but your IAT sensor will never see it so neither will the computer. Do a direct port setup, I don't personally feel the spray bar method yields the most accurate port distribution, if you fed both ends of the spray bar I think it would help but...
