Originally Posted by thewrx
(Post 5100707)
BAP's are a bandaid, and personally I would not risk my motor with one of those.
Its a fact increasing voltage to a pump will shorten its life. Increasing voltage makes the pump spin faster, which wears the pump faster. How much is uncertain. Could only be 1% difference or could be 50% in terms of lifespan.
Boost a pumps actually make fuel pumps flow less. Injectors might move marginally more, but overall it sort of cripples the fuel system. It really is a bandaid... Read Richard's thread for the proof.
Originally Posted by Atomic
(Post 5100765)
Your hobbs switch is triggering another pump entirely, no..?
Originally Posted by smokeshow
(Post 5100780)
Thats weird. Is the primary circuit isolated?
(Post 5100809)
I do know it's wired in line with the gray power wire going to the fuel pump from the fuse box, if that helps. |
Pumps flow more at lower PSI (to a degree).. it sounds backwards and hard to wrap your head around but Richards thread explains it pretty well
Originally Posted by TX Tahoe Z71
(Post 5100828)
You're over my head :(
