magnacharger 112
#31
Yeah the housing. I don't know how hot I dont have a heat gun. But it was hot enough to get me concerned. I have it mounted where you can read the bosh sticker. I figured that was the write way. I couldn't mount it where it said to. But the water inlets are facing toward the ground and the wires point towards the hood. If that makes sense.
#32
Ok drove it for about 30 min today. Bosch pump gets hot enough to we're I can't touch it. Anyone have any idea if this is normall. Checked that it does pump the water. Comes out of the supercharger into the resvior through the intercooler then it's the pump then into the supercharger. any suggestions. Or anyone ever touched their pump.
#33
Sounds like you may have it mounted upside down. The wire harness should be on the bottom with the pump mounted vertical. I think you can mount it horizontally as well, but double check me on that.
Mine gets really hot too, don't know if it's too hot to touch though.
#34
Trying to hook boost gauge up on mp112. Don't think I'm doing it right all I can get are vacuum number. What or where do I hook it up to. Thanks sorry I'm sure this is a stupid question. I have a auto meter boost and vacuum gauge.
