Maggy Questions
Does 4-5 Pounds Of Boost Sound About Right For A Stock Pulley On A 112 Radix? If I Wanted To Add A Little More Boost,whats The Next Size Pulley?what Else Would I Have Too Do Besides Retune?
yeah, 5lbs is about right. How are you measuring boost, from a gage? You just got it on and already want more boost? lmao, you are in trouble, boost addict! What size pulley do you have now, a 3.4"? I found the drop to 3.2" to be very satisfying.
You might want to think about methanol if you are going to go into the 7-9lbs range.
Lol,its All Your Fault Trev,ever Since I Pmd You About Your Maggy,i Had To Get One.btw Yea The Boost Reading Through Gauge,andits Got A 3.90 Pulley On It Now.i Want To Add A Little More Boost,to Where I Dont Need Bigger Injectors.
To Be Honest,i Dont Know What Injectors Came In The Kit
Yea,i Have A Local Tuner,what Size Of Pulley Would You Recommend?to Atleast Push 6-7 Psi,i Mean It Moves Right Now With 4-5psi,but Im Just Trying To Prepare For A Race With One Of My Buddys Lightning.
nelson used to have diffrent pulleys and retune while there for more power...i went from stock pulley to 3.1 pulley that netted me 8 psi on a 5.3 so you will prolly end up with a 3.2 pulley...
You got the 43lb injectors with your kit (right?) you should be good to go. Do you have a local tuner?
