LSA Blower in 2000 silverado, Can I use LSA Map sensor?
#61
I just used a corvette regulator/filter so it returns at the stock filter location, but is returnless at the fuel rail. A return system is better, this was just simpler.
#64
the 1/2" ones are what are used mostly, the 1" ones were version 1, and are only sold now as special order, theres really not any benefit. I run the 1" phenolic ones on my yukon as a testing platform, going on over a year and 40k miles.
About20ninj45 (07-22-2017)
#66
i hope you mean engine speed not blower speed. but above about 6800 rpm all youre gonna do is throw belts all the time, regardless of what adapters you run. The spin down on the LSA blower is brutal, it carries a lot of intertia. as soon as you let off its gonna throw the belt. blower speed should be in a 22k range max, most guys run in the 19-20k range. id lower the engine rpm and raise the blower rpm. either of the adapters will work fine, the 1" ones were just the old version.
LaBlackIce (07-23-2017)
Cammed4ever
09-30-2015 03:38 PM
