LQ4 LS6 Cam + Boost thoughts?
Old Feb 3, 2014 | 05:03 PM
GRRR65GTO's Avatar
Do a timing chain too, $30 for a new one
Old Feb 3, 2014 | 05:28 PM
stroker87's Avatar
i'm going to do a stall thinking around 3k since this is a DD so that should help with getting this truck moving, I know its not the best cam but right now it fits my budget and leaves me some $$ for the other stuff needed
this is what I plan on doing
317 heads 3 angle valve job maybe port (depends on cash)
ls6 springs or better
ls6 cam
ls9 mls gaskets
ARP head bolts
timing chain
water pump
oil pump
of course what ever other gaskets are needed
any thing else the "should" be done while the engine will at this state?
Old Feb 3, 2014 | 06:13 PM
How many miles are on this LQ4 ?
Old Feb 3, 2014 | 06:22 PM
stroker87's Avatar
I bought the truck with it already in there the owner said 90k on this one its from a 2001 HD
Old Feb 3, 2014 | 06:34 PM
If funds allowed I would go ahead and do the ls7 lifters, they can be bought for 120-130 new. I would skip the water pump unless it's bad and dont forget a new crank balancer bolt. Also if your on a budget use the ebay studs instead of the arp bolts.
Old Feb 3, 2014 | 06:37 PM
gamble686's Avatar
Hardened pushrods.
Old Feb 4, 2014 | 05:07 PM
stroker87's Avatar
now looking for a cam that will be good for my turbo'd lq4........
Old Feb 4, 2014 | 06:49 PM
GRRR65GTO's Avatar
Like I said stock48's isky triple 12, if its good enough for for kyle at kb racing who builds turbo kits its good enough for me
Old Feb 4, 2014 | 07:02 PM
stroker87's Avatar
I tried to fine that cam and didnt have any luck? you have a link or any thing?
Old Feb 4, 2014 | 07:04 PM
GRRR65GTO's Avatar
Yeah you wont find it, its a custom grind. Go pm stock48 on here and hell hook you up. I got my valve springs from him too. Tell him your whole planned setup, he gave me input on mine
