Low on power?
Just dynoed my 6.0 at 22lbs boost, e85 , billet s480, 218/218 cam, 4" exhaust, 15 degrees timing and made 704 rwhp. This is through a 4l80e, ford 9 inch, and unlocked converter.
Seems low.... yay or nay? |
What gear was the pulls done in? I've seen 620whp @15 psi on e85 on 16 degrees of timing, i don't think your to far off tbh, but what do I know?
Originally Posted by Razor
(Post 5394902)
Seems low.... yay or nay? Do you have any other power numbers to share, what was it at 10-15-20psi? |
How rich was it?
Treadstone 1300 vertical flow intercooler.
10 psi was 520 ish..on e85
(Post 5394908)
First off, I've never been a big proponent of dynos. I ran at the track, a lot.
My best educated guess is that your converter is turning into an oven. I needed the absolute tightest converter CircleD could make in 258mm in order to hold 22 psi, and even then it was not as efficient as ideal. If you have a converter designed for lock up under power, I would suggest doing that and re-dynoing. Or, log converter slip thru your datalogger if you can. |
Trv259 intercooler from treadstone
Its a Pro yank single disk converter. Not going to lock this one up on the dyno.
I was just anticipating more rwhp as I made aroun 630 rwhp with a 2.3 whipple at ~14 pounds boost. |
| All times are GMT -5. The time now is 05:06 AM. |
