kb racing kit.- where to route cold air intake
Old Dec 19, 2011 | 10:27 AM
Sweetser54's Avatar
Default kb racing kit.- where to route cold air intake
Im sucking in really hot air just using a cone filter directly on the turbo. im Trying to lower my IAT anyway i can. Where have you guys routed your cold air induction? pics would really help. Ill be switching the water to air out for a new Air to Air setup. thanks!
Old Dec 19, 2011 | 10:42 AM
OnyxSilveradoSS's Avatar
I would try to get it to behind the headlight like stock, the inner fender is where the stock airbox pulls from but the hole is probably not big or round enough
Old Dec 19, 2011 | 10:53 AM
Atomic's Avatar
I have a gauge for that
Works even better if you take out that metal plate that the factory airbox attaches to. I wouldnt recommend taking out that plate if you go offroad, however.
Old Dec 19, 2011 | 11:00 AM
Sweetser54's Avatar
thats a good idea thanks. Anyone else have any different ideas? jus trying to get all my options.
Old Dec 19, 2011 | 11:05 AM
Atomic's Avatar
You could get even fancier and add another bend and piece of pipe to point the filter down lower towards the front bumper corner.
Old Dec 19, 2011 | 11:28 AM
black00chev's Avatar
Slowest turbo build ever!
I believe foose04's is routed this way. Search his name for pictures. I also plan on doing the same myself.
Old Dec 19, 2011 | 12:43 PM
lglowe's Avatar
I don't know how much its gonna help my iats but I'm building a custom sheetmetal scoop from my factory fog light holes to the bottom side of my airfilter in the stock location. Only thing that's holding me back from finishing is my welder broke down.
Old Dec 19, 2011 | 06:58 PM
kbracing96's Avatar
This is how I have mine. Airaid CAI and made the 90* elbow.
Old Dec 19, 2011 | 07:40 PM
TrickTurbo's Avatar
Truck Sponsor
Install stock or aftermarket air box. Route inlet from turbo to air box. You can cut a hole in the air box in the front to match the area behind the head light. And/or cut the front bottom area out and route another duct down inside the front inner fender.
Or
even install the air filter there like we did here a few years back. Took the stock mounting plate. Cut a 4" hole and routed tubing to the new filter location.
Old Dec 19, 2011 | 07:50 PM
Mangled03gmc's Avatar
Baltimore Whore
I am curious to see logs on diff location.. The air is getting cooled via the IC..
