-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Just Back from the Dyno (https://www.performancetrucks.net/forums/forced-induction-159/just-back-dyno-507427/)
GONEB4U Sep 8, 2012 10:32 PM
Just got back from dynoing my truck today. Stock bottom end, Comp Cam with Dual Gold Springs, 60# inj., 6L80e swap, 2500 stall, Trick Stage 3 Intercooled Turbo Kit. At 6 psi it made 440 rwhp @ 5300 and 542 rwtq @ 4000 on a Mustang Dyno. Took awhile to get the right spring in the wastegate and get the boost under control. Had a couple of scary moments at 14psi making 660# of tq at 4200. Looking to upgrade the fuel pump so next time I go back, I can turn up the boost to 10-12psi. Does anyone know if a flexfuel pump assembly fits a non flex fuel nnbs with no mods? Plug and play?
black00chev Sep 8, 2012 10:49 PM
Damn, 100ft/lb more torque then HP has got to feel awesome! Im guessing this is a 6.0/76mm combo?
GONEB4U Sep 8, 2012 11:08 PM
You guessed right. :cheers: It does feel real good but I'm hunting for the 525rwhp range. That should land me in the 600# TQ range. Then I will be very happy.
black00chev Sep 8, 2012 11:24 PM
What cam are you running? Seems like it might be a low duration, low lift cam to get those kind of torque numbers.
GONEB4U Sep 8, 2012 11:30 PM
228/238 .571 .586 117lsa
lglowe Sep 9, 2012 10:34 AM
I'm guessing the turbo is a little undersized is why the torque is so high. Nice numbers
GONEB4U Sep 9, 2012 03:46 PM
Its a 76mm with a .96 ar exh. housing. I think its perfect. Boost comes on almost instantly. WAY better then my old 6.2 P1SC Procharged kit.
V3NOM GTO Sep 9, 2012 05:16 PM
Nice numbers. If you decide to go bigger on the turbo let me know, I think it'd be perfect on my truck. :)
lglowe Sep 9, 2012 09:24 PM
The compressor is fine. I was talking about the turbine pretty much.
black00chev Sep 9, 2012 09:36 PM
Yea seems like those 76/75 turbos are ideal for a 6.0-6.2L and the p-trim and q-trims are good for 4.8/5.3s.
In any case, those are great numbers for 6psi. Cant imagine what 10-14psi would be like.
