Intercooler tank water level?
I installed a larger water tank for the supercharger and Im not sure how much to fill it.
Option 1: Can i completely fill it even tho that will submerge the water return inlet? Option 2: Or do I need an air gap between where the water comes back in and the water in the tank? Thanks. |
You can submerge the return. Just make sure the feed has enough coolant that under accel it doesn’t suck air. |
Got a quick question on this subject because I am in the middle of my FI engine install. Is installing a bigger cooling system (tank) for the supercharger make a big difference?
i have a 10 gallon reserve. it just seems to postpone the inevitable heat soak...someone with more experience may confirm/deny my observation.
I agree with this reasoning. I added a trick tank in my battery location for that reason |
(Post 5459375)
