intercooler / intake rebuilt ...
i got tired of the intake it was just too big and got in my way when ever i needed to work on some thing so i decided to cut it down and mount it in a new location.....
you can kinda see how it looked b4 , it ran all the way over to the stock air box location, just cluttered the engine bay ...
now what it looks like ...
i also been working on coupler LESS intercooler set up for a very long time gathering peices here and there and this is what i cam up with . using 2 silicon couplers only ( at the head unit, and at the throttle body) everything is in its stock position, nothing was relocated . although you had to cut the headlight bezel up pretty good to route the tubing through it.
the mock up...
after the welding ,raw right after it got welded hasn't been cleaned up or polished yet ...
yes ALUMINIUM v clamps welded into place...
the intercooler is a 4" core and all of the tubing is 3" if that tells you how thick that thing is.
a lil up close action of the weld job , i love to show these off...
i have a couple more trix im working on but thats all im going to show you for now. the piping wont be installed till i get a s/d tune if you were wondering where the maf was going to go.
the mock up...
Those are some pretty clean welds... I would let you weld me up some custom cold side piping if you wanted to.
Do you bend the tubing yourself or are you just cutting down pre-bent pieces? Is there room behind the IC for the transmission cooler to be mounted in the factory location?
Do you bend the tubing yourself or are you just cutting down pre-bent pieces? Is there room behind the IC for the transmission cooler to be mounted in the factory location?Thread
GXPJAY
Feb 13, 2022 08:15 AM
GMCtrk
Dec 18, 2015 04:47 PM
