Intercooled turbo iat?
Not all intercoolers are the same. Even eBay cores can vary from mfg to mfg.
The over size of the core is not the hole story.
11" tall how many natural air flow rows are there?
Is it a bar plate or tube fin? Design.
The thickness of the aluminum will effect the cores ability to transfer heat.
The import cores we use work
on 99% of the builds. 12 psi or less with the occation 15psi burn.
But for race and all out performance with Hi boost levels
I would recommend a USA built core.
Yes they are spendy but the design is better.With less psi drop across the core and better cooling.
Your other option install a thicker taller core if room allows.
