IATs and meth
My IATs stay about constant with meth, but without they usually rise 5-10deg after 3-5 secs of ~10psi.
The huge drops in IAT happen when people are getting liquid meth right on the IAT sensor, which is not accurate.
I am spraying 50/50 with a Snow kit and a #6 nozzle before the SC. The IAT is after the SC. IATs normally are 20-30 degrees above ambient and the meth keeps them roughly the same when I get on it. Sometimes the temp will go up 10-20 degrees initially, but then come back down during the run. When I let off the temp will drop 20 degrees for a short time and then end up back around 20-30 degrees above ambient.
Just recently hooked up my Ultra-gauge so I could watch my IATs, so still figuring it out.
I have my Meth controller set to max spray at 10 psi. Still playing with the max setting trying to determine what works best. If I get it too low it bogs it down at lower throttle settings.
TAPyvehc93
Sep 17, 2015 10:10 AM
