How much max timing are you running?
#33
#34
#38
#39
I played around with mine a little and without surprise it ran great at 16*. I was hitting a peak of 203KPA so I barely clipped 15PSI. I'm fairly certain it would have taken 17* too... but I didn't really have enough time to test that out last time at the track.
again thats a maggie 1900 running on 93 and Meth with the stock LQ9 compression of 10:1. My AFR through first and second gear was 11.2 with it fading leaner at the top of each gear ad high as about 11.8, and in 3rd gear where I hit my peak boost I was running about 11.0 on the Gas scale. For you Lambda guys that means .76 and dashing up to about .80 in first and second at the very top of the gears, and .75 in third.
