Pulley down or E85?
Pulley down or E85?
I just got a great deal on some higher flowing injectors (big thanks to AKlowriderZ71). They are 47lb at 43.5 psi, so prob around 53lb at our pressure.
I am deciding if I want to pulley down to 3.0" from 3.3" currently or tune for E85. It doesn't look like I have enough injector for both. They should both net about the same gains, prob 40-50rwhp. And going E85 should be break even cost since I have to run 93 already.
So which one and why???
EDIT: They are 47 lbs. at 39.5 psi, so around 57 lbs. at 58 psi if these online injector calcs are right.
So how much injector will my fuel system support? Current setup is stock FF pump (I have heard 250gph from Injector Connection.com), return style, Kenne Bell boost-a-pump. Lingenfelter says this about the BAP here:
Depending on your engine efficiency (brake specific fuel consumption, BSFC), the voltage boosted factory pump can support between 650 hp (supercharged or turbocharged applications) to 750 hp (naturally aspirated applications).
Yeah, wish we did that. It would be a great way to meet everyone, sadly, I've only met a handful of the people on here. I've actually started wrenching with some Grand Prix people because they get together almost monthly to help each other with projects. As much as I don't like front wheel drive, they have a few cars ticking off 10's and 11's.
