help with the HD tensioner from leftcoast32
#29
Hey Roman have you tried this??
The tensioner assembly mounts to a bracket, there is a pin on one and a hole on the other. There are two holes, I would venture to guess the original poster has his in the upper hole causing the tensioner to sit that way, remove the bolt that holds the tensioner in place and check the location of the pin. If there is two holes move it to the hole to the right.
#30
Crap, I need to check mine too. I just googled radix belt routing and posted the pic here because it looked right. Apologies if I misled anyone with my lack of due diligence
Good catch 03 Sierra, thanks.
Edit: I'm good, per the diagram.
