Help! Don't Know What Happened
Old Mar 17, 2015 | 09:54 PM
tim wellington's Avatar
Default Help! Don't Know What Happened
been driving truck pass 3 days. since weather been nice no problems,took off from intersection .truck pop back through intake not loud .I let off quick truck drove normal for about15 sec .then started going lean .now hard to start when it does start idles 18.0 afr .if you try to ease into throttle cuts off ,if throttle fast off idles it rev normal .have good fuel pressure not skipping .change front 02 sensors they were brown dust looking .only did out the ordinary was got gas from a new spot .I added my race gas concentrate as always .any body with ideas please
Old Mar 17, 2015 | 10:02 PM
George C....'s Avatar
Formerly ScreamingL
might of busted the intake open or youre dealing with a hurt motor
Old Mar 17, 2015 | 10:08 PM
MechE's Avatar
check your plugs?
Old Mar 17, 2015 | 10:14 PM
Default ??/
have check intake . I was not even running 40 mph .I doubt motor could be hurt.
Old Mar 17, 2015 | 10:36 PM
Formerly ScreamingL
speed has no issue with a motor popping but all of sudden lean... ive saw stock intake blown apart
you stated you checked intake, did you remove the intake and inspected it?
Old Mar 17, 2015 | 10:44 PM
Default fixed
changed my 2 bar sensor problem gone.
Old Mar 17, 2015 | 11:10 PM
MechE's Avatar
oh ****. really? damn. ive never heard of a map going bad. thats good though it was cheap lol
Old Mar 17, 2015 | 11:14 PM
Formerly ScreamingL
odd a map sensor all sudden goes bad
Old Mar 18, 2015 | 06:27 AM
Default bad map
yeap bad map .drove truck after change no problem .did small burnout ran fine.double checked swap them back out .problem came right back.glad i had a spare .odd to me was first time no codes. put new one in ran fine.on double check putting old one back in .through code 107 (map sensor)
Zacholcomb
Sep 3, 2015 06:14 PM
Fast86z
Aug 23, 2015 12:35 AM
JFortner5
Aug 20, 2015 06:13 PM
rudvirus
Jul 15, 2015 09:31 AM
rojeho
Jul 12, 2015 06:10 PM
