A little bit of help
I put a pro charger on a 02 Silverado 6.0 stock motor exhaust is 3 in manifold back duel to muffler tuner said 42 pound injectors or more it is a daily what are the best injectors for my application and should I tune again before I drive after installing . Also I get a cod for MAF every once in a while any help is appreciated. New to the game
Fuel injector clinic, fuel injector connection or Deatchwerks injectors are all good injector to buy. Any their 42-60lb/hr injectors will work great.
Don't forget about your fuel pump. I'd say a 255lph to replace the stock pump.
If you ask me I'd say ditch the MAF sensor and run speed density only using a 2 bar operating system that most of those P01 computers allow for. A 2 bar MAP sensor is required too so you can properly log and tune for boost.
Whatever you do, it must be tuned for. You won't want to drive the truck without a tune if you install larger injectors.
Hemi Killer
08-04-2003 03:51 PM
