-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   FAST Dual Wideband Crazy, or am I? (https://www.performancetrucks.net/forums/forced-induction-159/fast-dual-wideband-crazy-am-i-475250/)
04SilverCrew Jan 8, 2011 09:13 AM
After the 706 heads on my 5.3 went TU, i went with some 243's and since they flow a bit more... my tune is off. I already strapped it to dyno to check tune and afr was 12.3.
I put a slightly bigger pulley on to make the tune less off until i am able to get her tuned. But for now i welded in two O2 bungs and borrowed my uncles FAST dual wideband... just to see where i was at.
This thing is driving me CRAZY :confused: During a street pull, 2nd gear, sometimes bank 1 reads 12.3 and 2 reads 10.8. Then i check it again after work and it's the other way 1 is 10.8 and bank 2 is 12.3. What the hell is going on?
This FAST box warms the sensors before you start the vehicle and has had very little use. Could the box be bad? Bad sensor? I just don't know. I got so frustrated with the wideband i took it off and put the exhaust plugs back in. I guess i will drive her easy until i get the tune.
foose04 Jan 8, 2011 11:35 AM
Possible exhaust leaks? Also might want to double check the grounds.
Rick_Vor Jan 8, 2011 02:03 PM
Swap the O2's and see if the low reading follows it.
04SilverCrew Jan 8, 2011 02:27 PM
The low will jump to the other side on its own... read my OP. This thing is weird.
04SilverCrew Jan 8, 2011 02:30 PM
There's no leaks... I welded the bungs ahead if the cats. And what grounds? This is a stand alone box. It plugs into cigarette lighter then the sensors.
JoeyGC5 Jan 8, 2011 06:16 PM
If you pull the wideband sensors out and leave them free air, do they consistently register 20:1 a/f or larger? If so what does the LTFT and STFT look like?
04SilverCrew Jan 9, 2011 10:01 AM
What is LTFT and STFT?
JoeyGC5 Jan 9, 2011 12:03 PM
Long term and short term fuel trims, computers way of correcting fuel irregularities between computer and factory O2 sensors when in closed loop mode. You'll need a scan tool to monitor. Have you checked free air readings of the wideband though?
04SilverCrew Jan 9, 2011 01:23 PM
Yeah, they read 21 in free air. Now what?
JoeyGC5 Jan 9, 2011 05:45 PM
So the readings of 10-12 are only in higher throttle/boost, correct? What does the wideband read when doing normal cruising? how far back are the O2 bungs from your header collectors?
