electronic boost control
Old Jun 10, 2006 | 11:58 PM
macs406's Avatar
Default electronic boost control
Does any body have pics of the STS boost controler hooked up? I have one and dont know how to run the vacuum lines.
Old Jun 11, 2006 | 05:40 AM
hemifever's Avatar
This is how mine is hooked up. I use my vacuum/boost sources off engine vacuum vs. the compressor.
Old Jun 11, 2006 | 01:32 PM
macs406's Avatar
what is the difference in using the vacuum source of the intake rather then the compressor?
Old Jun 11, 2006 | 01:41 PM
TIM Z's Avatar
11 sec. Truck Mod
some say the manifold source is more accurate. i reference from the compressor so i did not have to run an extra vaccuum line up to the manifold. Try the compressor reference like in the istruction manual. It should work fine, if it doesnt then just reference from your manifold.
Old Jun 11, 2006 | 05:32 PM
kenihemi's Avatar
The engine source is more accurate. You want to work with the pressure at the motor after any loses in the piping, IC, etc.
It also gets rid of some boost drop and variances.
Hemifever's drawing is right on the money.
Old Jun 11, 2006 | 06:00 PM
Avsfan's Avatar
I sure could have used that drawing a few months ago Hemifever... lol
Old Jun 12, 2006 | 05:45 AM
hemifever's Avatar
All you had to do was ask Avsfan. lol.
I used engine vacuum because I could never get a solid signal using the compressor as the source. I'd see 6psi, then 4, then 6, then 5, then 2, then 6. All in the same run.
GXPJAY
Feb 13, 2022 08:15 AM
greedygenius
Sep 3, 2015 06:51 AM
Razor
Aug 16, 2015 11:39 PM
lxcoupe
Jul 15, 2015 10:03 PM
