Efi Live users I need some help
#22
Ok no problem. It's just nice to have a baseline. As long as the pressure isn't creeping up at idle you know your regulator is able to keep the pressure down.
Im at work and only get a couple min here and there to get on here, so I can't look at your tune until tonight if I get time or someone else doesn't figure it out.
You said you had other good known injectors in this. Did the problem still happen when the other injectors were in? What size were the other injectors? Do you have B9021 available in your tune?
#23
#24
#27
no to be flippant but if it idles ok why do you care what your afr reads?
i have been running cos5 olsd and dont even have any nb o2 sensors and it runs fine. just checked my last log and it seems to idle 14.0-15.0. my combo is stock 4.8, 216/216 cam
i can send you my tune if you want, but dont use my timing table, i blew a hole in a piston two days ago
#28
TOTM: January 2007
I took a quick look at your tune, it needs some work. It appears you are running off the TPS VE map (see A004 and A005) and not the MAP-based VE table. Is that what you want?
I don't recommend this for a boost set up as 100% TPS will mean different values.
Also, your VE table needs a lot of work. It has a lot of peaks and valleys, it should be smooth and progressive until peak torque, and then taper off. Your PE threshold is set to 99%. Luckily, your open loop table is set to 11.5, but you are relying on that table for PE fueling.
Got to run, but start with those adjustments.
#29
#30
Also, your VE table needs a lot of work. It has a lot of peaks and valleys, it should be smooth and progressive until peak torque, and then taper off. Your PE threshold is set to 99%. Luckily, your open loop table is set to 11.5, but you are relying on that table for PE fueling.Got to run, but start with those adjustments.
