early model tvs1900 install advice
#32
Custm2500's Rude Friend
I went through the directions again. The Coolant crossover in the directions is the revised part to replace the early 4 port crossover. You might already have that. I think 99-00 and some 01's had the 4 port style. Then they revised it to 1 across the front and block off's in the rear.
#37
Like I said, this is going on my 2002 2500 HD that is stock with a muffler swap and CAI. I don't plan to do any supporting mods other than the blower to help with towing light loads (boat and Camaro). WOT power is fun, but not the main goal. it currently has a 2.8 pulley which should give roughly 10-11 lbs boost. anyone see any benefit to dropping the boost level to 7-8 psi for towing and keeping temps down? or should I just run what I have and send it at 10lbs.
