-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   CTS-V heat exchanger (https://www.performancetrucks.net/forums/forced-induction-159/cts-v-heat-exchanger-539089/)
terravast4 Aug 10, 2015 11:01 PM
anyone running the CTS-V heat exchanger? any pics?
5.0 Eater Aug 11, 2015 12:36 PM
I'm assuming your going to put this on your truck? Have you checked your IAT's that your running now? The only reason I ask is because the CTS-V HX is the first thing gone (upgrade) when you start overdriving the supercharger due to the heat problem they produce. We are talking about different platforms so I was curious to know your IAT's.
terravast4 Aug 11, 2015 12:57 PM
yes. Im gonna put it on my truck. right now here in 90-100 degree weather I'm seeing around 123 degrees on the freeway. Just looking for every way to lower temps
5.0 Eater Aug 11, 2015 03:50 PM
Is that doing a pull or just cruising?
ezdaar Aug 11, 2015 07:25 PM
Performance Interchillers - Chevy SS Forum
terravast4 Aug 11, 2015 10:33 PM
just cruising
5.0 Eater Aug 12, 2015 02:07 PM
Originally Posted by terravast4 (Post 5305904)
just cruising
That's a lil warm but not too much to pull timing. I have a stock CTS-V HX laying in the garage if you would like to check it out. Only 15K on it and its GM OEM.
