Couple Boost Questions
Old Jun 2, 2008 | 07:56 PM
dirt track racer 81's Avatar
Default Couple Boost Questions
First off Im going to put my 370 out of my white truck into my 96 s10 instead of a 5.3. the pistons are Mahle 4032 flat top pistons, with 317 heads how many lbs of boost can I get by with. would 18 be too much for these pistons? i wouldnt mind throwing a little nitrous off the line with this too..would a MP T-70 be too small of a turbo for my 370? 60 lb injectors be enough or do i need bigger?
Old Jun 2, 2008 | 08:31 PM
nonnieselman's Avatar
What would the compression be on that setup? Or is that what your tryin to figure out?
Old Jun 2, 2008 | 08:35 PM
7845's Avatar
Banned
you should be fine but some have lifted the heads at around 15psi.just remember psi is measurement of restriction. 15psi for you wont be the same as for the next guy
mp70 on a 6.0 will work fine look at stock48. he is your setup see his times?
2500ZL1
Jan 25, 2016 06:30 AM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Sep 7, 2015 05:50 PM
USMCvet0311
Aug 1, 2015 07:45 AM
