CEL after Whipple install
2016 Silverado 5.3. I'm getting codes p056, 057, 158 and 161. I can clear them and they reappear after a fairly short period of time. All have to do with O2 sensor circuits. Curiously the O2 sensor fuse is used as a trigger for the water pump so I suspect I wankered something but just thought I'd ask if anybody else has seen this.
hmm, sounds like you need a tune. Maybe the increase in exhaust flow and pressures is throwing off the readings. Of course I can only speak from the turbo side of things where we have to get a tune to drive.
Although, I did put a powerdyne on my 1997 suburban. Had it tuned on a dyno as well though.
Good Luck.
Good Luck.
It's not installed yet. The CEL thing has me flustered. I can clear the codes, start the engine, drive as much as I want and the CEL will not come on. At the next restart the CEL will go out for a few seconds then come back on. Very repeatable. Maybe it is tune related.
Using the scan gauge, both the O2 sensors in the 2 position show 1275 mv when cold. Turn the ignition on and after a short time the bank1 sensor drops to around 800mv and bank 2 stays at 1275. Acts like the heater isn’t heating.
