Ca. Smog
Can I make up my own CARB# stickers?
Do I have to flash a stock tune??
The only thing you need to do is make sure that all parts (Pulley,injectors,fmu,tune,etc.) that may affect the input/output of the system are put back the way Procharger intended when you go to Smog it. A CARB number does not mean $hit if your truck won't pass smog.If you are using a non Procharger way of tuning...make sure to tell your tuner you need a stock type tune to smog it. And as long as the intake tube you installed has all the same provisions as the one you removed you should be fine...Don't beleive anything you read on a Import forum regardind CARB stickers
sauldgold
Jul 23, 2015 02:15 PM
