Building boost @ the tree
I have now installed the turbo blanket and hydroboost and still can barely get a .5 lb of boost by power braking. It is better , as it would only get -.3 on my digital boost gauge before. Maybe my back brakes are glazed and crystalized from years of burnouts? By the way, hydroboost is great:drive:
Will the boost go higher at the track with the stickies on? Has anyone tried a two step on a small 2200 stall? What timing should I be running at 2k to 3k rpm to build boost? PM if needed. I need help! |
Sticky tires should help out with building boost as from what i have read, but I'm not positive as I'm not on the boost band wagon,...........................................y et:secret2:
We shall see tomorrow night. I think I should deglaze my pads and turn my rotors and see if that helps too.
Yea i bet that would help, you make sure to put you a good non-directional finish on em too!
get a 2 step.i got hydroboost and a 2 step and when i had the 4.8 i can build 2psi at 3k just on footbrake and 7psi at 3k with 2 step.
What rpm are you able to stall the truck up to?
Slightly off topic, but what high pressure hose did you use for your hydroboost conversion(2wd truck, right?)? |
Looser converter will take care of it.
do like my wife does, she grabs the bottom of the steering wheel and presses the brake as hard as she can. i can build about 7-8psi at the line with my 20's but i have a yank billet 3200. its very tight but as boost rolls in it climbs right to 3200. not sure if it helps or not but my timing in that area is rather low, 4-6* if that.
it probably helps that its AWD and has factory hydroboost and weighs 6020 with me in it. |
Originally Posted by gavin2005
(Post 4759942)
Originally Posted by Beatdown Z
(Post 4759972)
I can only stall to 2200 or so on the street. Slightly off topic, but what high pressure hose did you use for your hydroboost conversion(2wd truck, right?)?
Originally Posted by tarinitup
(Post 4759983)
Originally Posted by TURBHOE
(Post 4759990)
I can build about 8.5 psi on the foot brake. I'm sure my 3500 stall, 33" slicks and 3.30 gears are helping me. I have a set of 4.56 gears on the way so I'm not sure if ill be able hit 8 psi on the foot brake. I'll be happy with 5 psi and a 1.6 sixty foot.
| All times are GMT -5. The time now is 07:27 AM. |
