Boosted 370
Old Jul 15, 2015 | 10:05 PM
121's Avatar
121
Default Boosted 370
2007 nnbs Rcsb 2wd 370 s475 th400 with tbrake on 18lbs.
I have a 4/7 drop flip kit with caltracs. 15x10.5 mt et drag slicks. I setup my engine angle and pinion angle. My caltracs are 1/4 turn tight I have qa1 adjustable shocks in the rear. For the life of me I can not get traction after I launch. Hooks and 15ft later it blows the tires off. I've tried everything that I know. Anyone have this issue and what will solve it? Or any suggestions ??
Old Jul 15, 2015 | 10:45 PM
George C....'s Avatar
Formerly ScreamingL
ok first......
how do you have the rear shocks? you should have least 5" for extension and least 1.5" for compression....thats a shock that has 6.5" of stroke minimal
next you need to see if you are topping out your rear shocks
also have to see if you are topping out your front shocks
make sure you have absolutely not binding of rear suspension
make sure you have absolutely no binding of front suspension
read this before next post....it will take you a few days but read and read and read then read some more
caltrac setup - Yellow Bullet Forums
Old Jul 16, 2015 | 12:18 AM
121's Avatar
121
Originally Posted by George C....
ok first......
Ok george Ill check that out and reply back to you. I appreciate the help man. Unfortunately I'm at work and can only get on here and there.
OHsixLS3
Sep 25, 2015 11:20 AM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
USMCvet0311
Sep 4, 2015 09:43 PM
